1974 70hp evinrude?
alhase
I am having a problem with my evinrude and was wondering if anyone could tell me what the problem might be?
I was out this weekend and the motor was running fine. I pulled up to a spot to go fishing and when I throtled down, the motor started to make a grinding noise. I shut the motor down and started it back up and it still made the grinding noise. I felt the motor and it feels like the grinding noise is come from the power head. It sounds like it is stuck between gears or gears grinding. The motor starts and runs and the lower unit goes into both foward and reverse. It does not matter if the moter is in neutral or either forward or reverse it still makes the grinding noise. So my question is what is making the grinding noise? Could it be where the splines of the lower unit fits into the power head or is somthing else.
Thank you,
Alex
jjacobs007
Re: 1974 70hp evinrude?
Man thats gonna hurt! Yes do comp test that will give you something.Check your reeds behind barbs make sure theres no broken pieces.
jtexas
hard to say when you can't hear the noise.
is the starter motor disengaging after the motor starts?
