I have this '74 6Hp Im fixing for a customer. Some ha. Over tightened the low speed needle valve and the tip of the needle broke off and is wedged in the jet hole. Ive tried a mechanics pick To no avail. ANy ideas? Has this ever happen to anyone?
pop out the core plug covering the idle holes and that should allow you to see the tip of the idle mixture needle...try forcing it back out with something blunt
If it's really jammed in there, try a little heat as I believe the aluminum will expand more than the brass (or steel, depending on which needle you have) and loosen it up slightly. A shot of compressed air from the cavity under the freeze plug may blow it back out.
Drill a hole in opposite side of chamber that the welsh plug covered, and tap needle tip straight out w/small drift. JB weld the drilled hole, new needle and welsh plug, and off you go!
I grinded a roofing nail down almost to a point just small enough to fit in the whole, clamped onto it with needle nose vise grips and hit with ballpeen hammer. Still just bent my poker. Any other ideas? This part is unavailable so maybe someone knows of a boat salvage yard?
Drilled a hole in opposing side and got it out but jb weld doesnt hold. The oil and gas gets behind and just peels off or falls out. I got a used one for 75 off ebay. Runs great now
