1974 50 hp Mercury can removing the prop cause problems?
Turtlelips
I removed my prop and been having shifting trouble. Could I have knocked something out of place?
Chinewalker
Re: 1974 50 hp Mercury can removing the prop cause problems?
Removing the prop could not have affected the shifting unless you have other lower unit issues (loose rear carrier, missing spanner nut, etc.?). Did you remove the lower unit from the motor? Have you removed the motor from the boat resulting in the cables being misadjusted?<br />- Scott
Turtlelips
no i have never removed the LU only the prop. i cant even get the engine running now, it seems to be in gear while im trying to start the engine ,its barely turning over. this all happened when i changed my prop. I am confused !
Ben Konopacky
???why did you decide to CHANGE your prop?
Turtlelips
because the hub was spunn
Turtlelips
Turtlelips
