1974 50 hp Johnson outboard
Hard luck fisherman
Im having trouble cranking my 50 hp johnson. I’ve put new plugs and a new fuel pump on it. I got it to crank one time by spraying carburetor cleaner in the intake. I’m getting gas to the fuel pump but I can’t get it to crank. Where do I go from here?
jbuote
Hey there! :welcome:
Not a pro, but you said you have gas to the fuel pump, but is it making it to the carb?
Is this a new behavior? Is the engine new to you or have you had it? When was the last time the engine ran?
Carbs been cleaned recently?
Don't use carb cleaner. It doesn't lubricate.. You can put some pre-mix in a spray bottle and use that though.
With some of those questions answered, the gurus here will no doubt be able to help you out!
Hope it helps!
Cat nip
If it won't crank or turn over it is battery or starter issue, if it won't fire it is a spark, fuel or compression issue. Using the terms wrong will confuse some folks.
5150abf
Confirm spark on both cylinders, if yes do compression test, 110ish cold and with in 10% of each other.
If that is good points to carb issue, clean the jets, there are 3 I believe, use a stranded copper wire to clean them.
Pull back strands till it just fits, may look clean but aren't.
Do one jet at a time and replace then next and one carb at a time, mark them top and bottom to avoid confusion.
Hard luck fisherman
The battery or starter isn’t an issue. The model numbe for the motor is 50esl74m. I had it running last year until I went fishing. Then I couldn’t get it to crank, so I just used my trolling motor to get around. It hasn’t cranked since. I did put a new fuel pump on it because I thought it might be the problem.
jbuote
Yup...
Time to start at the beginning.
Do a compression test and an open air spark gap test. Set adjustable spark gap tester to 7/16".
Should be bright blue, with a crisp "SNAP!"..
Post your results of those tests.
You want to confirm you have good base health of the engine at this point.
