1974 45hp prop problem
toddr5516
i bent the prop that came with my boat which is a 1974 15ft. tidecraft . stick steer
what is the proper size and pitch that i need for this motor?
JB
Re: 1974 45hp prop problem
You will get better response if you repost this in the Prop Forum, Todd.
Good luck. :)
steelespike
You will get better help in the prop forum.
A prop shop can probably repair your prop.
Props are usually marked with diameter and pitch.
Difficult to know what prop you need without knowing how the present prop performed hopefully with rpm and speed. Also good to know how you use your boat,cruising,skiing etc.
