1974 15hp evinrude very little spark
sambrigman
So I pulled the flywheel and everything looks new.Sometime it will start and run for maybe 5 seconds and quit. This is my first old points motor and I just do not know where to go from here. The spark is very little. Could it be the coils? Both plugs little spark. Any suggestions, thanks
tomhath
Master Chief Petty Officer
The first thing I'd do is clean and gap the points. A voltmeter helps to verify the electrical contact is perfect, anything less that that or the wrong gap will give a weak spark. If it still has a weak spark or quits after a few seconds I'd replace the condensors.
Honorary Supreme Mariner
Perhaps it needs a new driver coil, the one under the flywheel.
