1974 15hp evinrude low compression help...
wolfman77
motor starts easy and runs good. but has low power and wot rpm. compression is 35psi in both cylinders when spinning motor by hand. I even compression tested both cylinders while running on one and testing the other and still only got 60psi. removed bypass plate, pistons are clean and smooth, rings are not stuck. im stuck on why compression is so low. could the ring grooves be worn to allow blow by? any ideas appreciated.
Re: 1974 15hp evinrude low compression help...
You say it runs " good " but has low power ????---------Try using another compression tester as your gauge is suspect.-------Could be a problem with the head gasket to.----Exhaust housiing could be plugged as well.
nwcove
i really doubt the motor would even start with 35psi, so as mentioned, try another guage. and plz dont do the test while running the motor! thats a good way to fill a tester with fuel and making it useless. id try an aggressive decarb with seafoam or the likes.
boobie
Agree............
Bosunsmate
Inspect your headgasket for blow by failure, inspect the head, then check you have spark in both cylinders.
