I recently bought a 15 hp evinrude 15404s serial #. Seemed fine when we bought it, granted I knew next to nothing about the inner workings of an outboard motor. Come to find out it only runs on one cylinder, which is the top or #1. I had suspected this was the problem when I took it out on the water and could only go aobut 5mph on a 14' starcraft. I finally narrowed it down to the # 1 cylinder after a carb rebuild, and new fuel pump. It seems to have mild backfires at idle, which after playing with the lean/rich setting I could get to stop for the most part. I am getting a good 1/2" purple spark to the side of the block while testing the plugs, so I would assume this rules out any ignition problems. However, today I pulled the off the top coil and found a nice big hole burned in the side. So hoping this was the problem I quickly replaced it with one from a 9.9 I also have. Unfortunatly this did not solve the problem. Another thing I noticed is the mild backfiring seems to stop as soon as I pull the plug boot from the top cylinder. I have learned a lot over the past weeks, but I still have a hell of a lot to learn. Oh also I did a compression check using the electric starter and wound up with 120 over 112. I had heard that I could wind up with an incorrect reading because I was using electric start over and over and that it would just keep raising the pressure. However I had also heard that once it hit max compression it would stop. I have been tearing my hair out over this for weeks so any input is welcome.
