1974 115 tilt motor... need a replacement
kwinnc
I had my 1974 115 TOWER OF POWER (echo echo echo) in storage over the winter. Some real nice person decided they needed some of my parts such as my throttle control (just cut out), and ONE tilt cylinder cut out at the hydraulic lines. :mad:
Soooooo I am looking for a replacement along with the proper hydraulic lines. I already have a new (to me) throttle control and cables.
Any good suggestions as to whre to being to look?
Thank you!
Chris1956
Honorary Supreme Mariner
Re: 1974 115 tilt motor... need a replacement
The cylinders are fairly easy to come by. Try any OB junkyard, or used motor parts place on the web. You can always rebuild them if they need it. The lines can be had from a dealer. The pump motor is the tough piece.
kwinnc
Thank GOD they didnt take the pump motor!!
Guess I better start looking up a OB junk yard. Got to be one around these parts. Just new to the area.
Thank you for the response! I never needed to replace one of these before.h
