1973 teleflex.tach wiring?
lineman71
Could someone tell me what wires go where? There is a white, blue, orange and black. The white and blue are for the light inside. White is hot and blue is ground, pretty sure about this. So, where do the black and orange go? The boat is a Glastron swinger with a mercruiser 165. Any help is appreciated.
Silvertip
Honorary Supreme Mariner
Re: 1973 teleflex.tach wiring?
Is there a letter code along side each terminal or do the wires you mention go directly into the tach? How old is this tach? Normally to make a tach work three connections are required: +12 volts with the key on which is normally a purple wire. That same wire by the way, feeds the "I" (ignition) terminal on every other gauge. Connections are simply daisy chained from one to the next. Same for ground. The tach also has a "sense" wire which connects to the sense lead in the engine harness. That lead runs back to the ignition coil if this is point style ignition. That wire does not connect to the ignition switch. The light terminal connects to the load side (Nav terminal) on the Nav/Anc switch.
lineman71
The wire go into the tech. There is black white blue orange.
