1973 Starcraft
Jammer79
Re: 1973 Starcraft
Thanks. I know the Nova needs a long shaft I was just wondering about the motor. I guess since it is a 60 hp with power trim that it would be a long shaft. I haven't seen the motor myself so I guess I will see when I get there.
barato2
Re: 1973 Starcraft
pretty sure you're right that it is roughly a 20" shaft, altho for some bigger motors, that is the "short" shaft....they also come in 25"
Jammer79
Re: 1973 Starcraft
Jammer79
Re: 1973 Starcraft
OK. Got the big 60 on the little Nova! As soon as I can figure out the wiring I will be in business. It came with all the controls except battery cables? Not sure whats up with that.
ezmobee
Re: 1973 Starcraft
The battery cables should be easy to figure out and don't really tie into the main harness at all as I recall. You shouldn't need "genuine evinrude cables" either. Just the needed length of heavy gauge wire with crimped circle connectors on each end.
heyyou325
Re: 1973 Starcraft
Other than the batterry cables, my 40, as I remember has 2 wires to selonoid for electric start, and I think that's it. Then your steering cable.
Jammer79
Re: 1973 Starcraft
Just picked up the battery cables. The control wiring has a harness so I will just have to plug that in. However their are like 3 or 4 wires that each have connectors on the ends. The wires are all different colors and may not do anything I need anyway? Not sure. the motor has power trim and is oil injected so they may be trim or alarm wires? I plan to plug the harness together and see what doesn't work?
barato2
Re: 1973 Starcraft
not sure that's a good plan. find or invest in a shop manual and find out what they do before you apply power to the system and for sure before you fire it up.
Jammer79
Re: 1973 Starcraft
I know the video is rough but you all get the idea. She is on the water and running strong! The restoration begins this winter and I cant wait. Thanks for all the advice!
roscoe
Re: 1973 Starcraft
YEEHAH !! Looks good, sounds even better.
