1973 SeaRay SRV200 prop Size
hykv4ster
I recently acquired a 1973 SeaRay SRV200 with a Mercruiser 888 (188hp) I/O. Does anyone have any idea what the stock prop size was for that boat? I am pretty certain that the prop I have is wrong; I am only getting 3700RPM WOT and at idle speed it is moving way to fast. The prop that is on it is pretty beat up and I can't read the marks. I contacted SeaRay and their records don't go back that far. Any help would be appreciated.
steelespike
Re: 1973 SeaRay SRV200 prop Size
Best thing would be to get the prop repaired ,if possible, and then run it to get a base line.They can tell you the size.You really need the rpm and speed.without there is no way to tell how well the prop or motor is working.
SRV200 I believe is 19' a total guess on the prop would be a 21"
