1973 Mercury 500 thunderbolt questions?
Sacky661530
Was wondering does this motor have a alternator or charging system? I want to put a little stereo in my boat but don't wanna drain my battery. Also wanna make sure it's charged up.
schematic
it likely has a unregulated charging system. best be upgrading it to a regulated rectifier if you want to run electronics
Sacky661530
So is there any way to find out if it charges my battery while it's running at least? And where is this rectifier located?
GA_Boater
Electric start model? If yes, it has a charging system. Put a meter across the battery posts while it's running and the voltage will increase as the RPMs increase.
A regulator isn't needed for electronics. Not the best thing, but the battery acts as the regulator and electronics is tolerant of a range of input voltages.
schematic
true if your battery is in good condition, but as it ages, the internal resistance increases allowing voltage to climb. once you hit 16v - 17v you run the risk of smoke.....just saying. If its a cheap stereo, who cares...
jimmbo
Those unregulated systems don't put out a lot of current even at peak output. In most cases they don't get/keep a battery fully charged during the course of a day. However they do require a Wet Cell Battery that permits the Electrolyte levels to be checked and water to be added. That means NO Maintenance Free batteries or AGM(Optimum) type batteries.
