1973 Johnson 6hp outboard. R673S
Frickernator
Hi there, im in New Zealand, and im trying to restore this outboard,
Im looking for -
1, the turn knob that holds the cowling on. 2, the forward reverse lever, 3, the plastic levers for the turn-screws that holds motor to transom. 4, AND LAST BUT THE MOST IMPORTANT, a couple of the pins that go through the drive shaft, that holds Prop on.
Thats
Honorary Supreme Mariner
They are going to tell you that this is not the " shopping channel " here.-----Check on e-bay as they are likely listed there.
