Re: 1973 johnson 6hp help
I bought a nice little '68 6hp this last summer. When I rebuilt the waterpump I was oblivious to the "pin issue" with these motors. I don't recall having any specific issues removing or installing or l/u, though I might have rotated the flywheel during the process... don't exactly remember.
Anyway... this thread got me curious. So, I consulted the online parts diagram. Indeed, it does show the pin. It also shows items #1-6. I don't recall seeing these attached to the driveshaft. So - where are these located? Are they possibly installed in the powerhead? And what does the pin actually do?
A bit of history: Up until around 1964-ish or thereabouts, the seal parts were stacked on top of that pin and you had to remove the powerhead in order to remove the lower unit. If that were not so, the seal would all fall apart with no reliable way of getting it back together.
Then they put a ledge inside the housing to retain the seal parts, with that slot for the pin to come down through. That eliminated the falling apart when the shaft was removed.
Now in your case, if somebody forced it off without aligning the pin with the slot, they may have sheared the pin off. If that is the case, it is not supporting or rotating the seal parts. That seal is vitally important. If it is defective, incomplete, or otherwise leaks, it will admit just enough water into the crankcase to destroy the motor over time. Worst thing is, you don't know until it is too late.
Personally, I think the powerhead should be removed every time the shaft is pulled, whether it needs it or not--just to check the integrity of that seal. Maybe I'm over cautious, but my motors don't throw rods either.
