FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Both systems were available as OMC Accessories. Power Tilt & Trim for long shaft motors only, Power Tilt (only) for long and/or short shaft motors. The Power Tilt & Trim is easy to recognize by the honking big plate bolted to the rear of the swivel bracket, with hydraulic cylinders on both sides.
This is the plate and it has 2 cylinders. Also there is no solenoid that I can see?. 3 wires from motor to switch. Tilt works well but bleeds down. Is this power trim as well?
That is tilt only. One cylinder is for the tilt, other is a shock absorber. Without the tilt kit, there were two shock absorbers in there. It did not use a solenoid.
