1973 Johnson 50hp Not cranking
mjajstrand
1973 Johnson 50 hp, model number 50esl73R. I have power to the dash, electric choke works, the engine just wont crank. I have power coming into the solenoid, but not out of the solenoid. I have replaced the solenoid, jumped the terminals on the solenoid and the starter cranked right up. I have also replaced the ignition key switch. Where do I go from here? I tried to bypass the neutral safety switch but I am somewhat confused. It says to splice the two red-yellow wires together. I only have one yellow-red wire coming from the engine harness, the wires coming off the neutral safety switch are yellow-black. Any help is appreciated.
Honorary Supreme Mariner
Look on the side of the motor block.-----Look for a switch with a white wire.-----Hold that white wire to the motor block.----Will it crank now ??
Crosbyman
if the selenoid does not "pull up" to feed 12 volts to the starter the Inside coil is open or you have no +12v from the start key
measure from the start wire on the selenoid to frame ground if you see 12 volts when starting. Make sertain the selenoid body is well grounded/screwed down to the engine frame.
if you see +12volts and the engine does not crank the selenoid coil is open
to confirm... test with a new or spare selenoid or measure the inner winding with an ohmeter Frame ground to selenoid start post you should see low resistance if you need infinity the coil is open and no good
if you do not see +12v in" start mode" on the selenoid control post .... work back to the key to find out why ( broken wire between key and selenoid.... no +12v leaving the post on the start key... no +12v reaching the key assembly... neutral switch open or defective jiggle it...
mjajstrand
I will start at the solenoid and get readings. I am assuming i need to do this with the key turned to start? Which terminal on the solenoid for voltage the large one coming from the positive battery? and check resistance through smaller terminals with key turned to start?
In post # 1 it was mentioned that electric choke works.--This says that the fuse is good.----Not sure if the OP has looked for the wee switch on the engine block ?
mjajstrand
i have 12+voltage everywhere but out of solenoid. I found that switch with the white wire and poked it with a screwdriver and the motor cranked. I have now removed the switch. What exactly is the part and what does it do? What a relief to hear that motor crank, it has been 3 weeks working on this thing.
mjajstrand
hardwater fisherman
No Title
If it looks like this than it is a neutral safety switch which prevents starting while in gear.
It pays to follow simple instructions.--That " wee switch " is easy to take apart for cleaning if need be.--It may just need to be adjusted.---On those motors for some reason there were 2 safety switches one in the control ( nuetral switch ) and one on the block that prevents cranking when thottle is open to far.
mjajstrand
So i guess ill tear it apart. Does the throttle make contact with that then and if it pushes to far it trips the switch?
hardwater fisherman
No I think it is the other way around when the plunger is pushed in it grounds the solenoid. Which allows current to the starter. At least that is how the neutral safety switch works. And it is the same part number as my neutral switch on my motor.
Crosbyman
"ground" is not used to activate a selenoid...
it is a simple " one coil" electro-magnet switch whose inner coil is already grounded one side to the engine frame...
To "pull up" o rclose it's internal contacts it needs a +12 volts from the "start key" internal contacts which takes it from a Bat+12 v supply pin
The start key position then transfers it (12v) to the key's selenoid wire back to the selenoid
The +12v post ( fat red wire) on the selenoid is then transferred out... to the starter's fat red wire to cranks it. .
Sorry but post # 15 is wrong.--On these motors the pick-up coil is NOT grounded internally !--It is fed to ground via the second small terminal and the white wire at the " too much throttle safety switch " on this particular motor.
hardwater fisherman
I know that ground does not engage the starter, something mechanical needs to push in the plunger on the switch.There is no voltage flowing through this switch as far as I know.
There are numerous wiring diagrams available " online " that explain the starting circuit on OMC motors.
