1973 Johnson 50hp no spark
voldie
I have a 1973 Johnson 50hp .Had on the lake a couple of weeks ago .Ran fine ,put on trailer ,towed up north for a week of fishing .No spark ,changed out power box and regulator ,still no spark.Isolated kill curcit ,not the problem .ohm out trigger ,resistance keeps rising then dropps out to open .
oldboat1
If you installed a new power pack and regulator, look in particular at the instructions for the CDI power pack -- could have a bad rectifier, as I read it. Troubleshooting calls in part for disconnecting the rectifier if you have no spark, then see if spark is restored.
The CDI stuff is copyright protected or I would lift it. Try the marine engine site and look for the ignition diagram for your motor. Check the link to CDI technical info for the CDI power pack (113-1397 - Power Pack PP2, 581397 -- was unable to locate it here at iBoats, but may have missed it.)
