Gonzoman89
Thread starter- Joined
- Apr 9, 2015
- 7
So I just purchased my first boat. A 1983 sea nymph 16.6ft aluminum V hull boat. The motor is a 50hp Johnson ESL73R. I checked the compression, changed the lower unit oil, the plugs, cleaned the carbs and changed the impeller. I took it out a few days ago and u set my pole on the key. I pushed it down on the steering wheel and actually bent the key. I trolled around for about 30 minutes and when I went to leave the motor would not turn over. It smelled like electronics when I took off the cover. I was able to start the motor with a pull rope. I figured the solenoid blew so I ordered one and replaced it today. I still get nothing when I turn the key. I checked all the connections and verified they were good. So my question is if I should check anything else before I replace the starter? Any advice would be appreciated! Thanks in advance!
