Bradster61
Thread starter- Joined
- May 7, 2007
- 5
I replaced the lower unit which was the large gearcase mechanical shift, with a 1975 small gearcase lower unit Mechanical shift and now the rotation is backwards (LH). Since nobody makes LH rotation props for the small gearcase I need suggestions to remedy this problem. Tried flipping the control but can't obtain WOT. Does'nt appear to be any way either on the control, engine or lower unit to fix this problem.Shifts into F,N,and R fine Just backwards Thanks for any suggestions!
Brad
Brad
