1973 Johnson 50 HP Power Shift2 Lower Unit Oil?
Milliner10
I have a ? That's kinda on the same topic and sense I'm new to this board and can't figure out how to start a new thread I will just post it here. I have a 1973 50hp Johnson power shift2. What type of oil do I use in the lower unit? And where do I buy it at?
GA_Boater
Welcome aboard, Milliner
Started a new thread for you. You can start a new thread by clicking the +New Topic button at the top of any forum thread listing.
Vic.S
What does AFAIK mean ????
AFAIK = as far as I know
Often wonder about the oil for these hydraulically assisted manual shift gearboxes....... If the hydraulic / electric boxes need a type C oil why don't the manual ones ... or do they? I always assumed the type C oil was a lighter viscosity grade for the pump.
Also wonder why type C seems to be specified for the non-hydraulic electric shifts ... or is it ?????/
boobie
You have to use the type C or Premium Blend in the electric shift gear case. You can also use it in the hydro-mechanical gear case. But you can get by with 80w/90 in the mechanical one. There's been some peeing contests about that.
