1973 Johnson 135 hp Powershift II shift rod measurment
RHGary
I replaced the water pump and while the lower was off the shift rod got moved, completely unscrewed by my wife. In the top secret file it says all motors 1973 to 1981. It does not include my motor! I have a 4 cylinder, Johnson 135 hp powershift 2 that is 2 stroke, with what I have read is a bubble back????? I have the motor running and I can shift it from neutral to reverse but not forward, Any and all tips or tricks to go along with the correct shift rod length would be much appreciated.
Honorary Supreme Mariner
??----As I recall the shift rod itself does not unscrew on a 1973 model.-----The adapter screws off the top.------Is that what happened ?
RHGary
Yes, that's exactly what happened. And with the lower off I really cant tell where neutral is and where reverse starts. Think it has something to do with the whole Powershift part of the lower
RHGary
Yes just by hand, I spin it in clockwise rotation. When I replaced the water pump it was acting the same way. when I reinstalled it to test the pump it seemed to work correctly, well all except shifting into forward. the adaptor needs to be raised from where it is now so I have enough stroke downward on the shift rod to engage forward.
Do not have the factory manual handy at the computer today.----As I recall you screw the adapter all the way down and then back it off for the correct offset.---------Some will argue that.
RHGary
How much to back it off though??? From the top of the lower housing to the center of the hole in adaptor I'm at 21 1/2 inches. If the rod is in the right gear, At this point I'm not even sure where neutral is, or were where reverse or forward start. My lower appears to have a pump inside that pushes a servo to aid in shifting. without the pump spinning fast enough it doesn't want to shift cleanly. This is the 4th time I have dropped the lower in 2 days that's why I'm looking for the correct length on the adjustment.
As I recall it says to screw the adapter all the way down and back it off enuff.for the correct offset.---And no I am watching a ball game at the moment and no time to look for the manual.----And I can overhaul one of those lowers without the manual as well.---I know how they work and what is inside that case.
RHGary
Are all the 1973 through 1976 models the same. Was thinking about serving online for different year model.
