wv_transplant
Thread starter- Joined
- Jul 18, 2010
- 16
I have a 1973 johnson 115 outboard motor. Im getting 90 lbs compression on all 4 cylinders. Is this good? What should the compression be for this year motor? The motor is clean and looks in excellent condition. It starts up quick. I was told to check the compression with all the plugs out and with the carbs wide open. I would really like some advice from some of you local pros here on ihub. Thanks for reading and have a great day
