1973 ISLANDER REFIT
Status
Not open for further replies.
ShoestringMariner
Hey, I saw your boat listed on the Jij! You’re a S. Ontario guy too?
I’m watching this thread with much interest!
if you need some 5/32 dis. solid rivets, I’ve got a ton in 3/8 and 7/16”. Though you probably need 3/16” diameter....
DarrinT
Cool boat and history! Hopefully you and your helper are still friends by the time you splash 🤣 .
Being honest here, that's a really aggressive schedule (4mos) especially on such a large vessel. With it leaking as much as it is, you may more than just a few compromised rivets; these older models were prone to fatigue cracks in the outer chine & spray rail. Corrosion has also knocked more than a few projects off of their rails.
Lookin' forward to the tear-down to see what kind of canvas you're working with!
Zero corrosion and cracks
Boat was owned from new by a guy that only used it two weeks every August and other wise stored it indoors !!!
Bought from first owner by brother of good friend who had it for 2yrs then I bought it in 2007 for $4250 CDN
In the ad for sale I calculated that my yearly cost to buy, maintain and repower was $650 CDN !!!! You cant rent a boat of this size and capability for one day for that!!!!
Contractor buddy has worked on a reno for me and rocks.
He's a machine that likes to do ten hour days and is a perfectionist.
He lives 5 min away and I'm mostly equipped in my shop/garage.
Should work out.
DarrinT
Oh! that would rock . I'm on the bluffs in Scarborough.
Where do you boat and what Model
ShoestringMariner
I’m on the other side of the GTA.
mostly small lakes in Wellington county, grey-Bruce. With trips to Huron, Lake O west of T.O. And the French River.
I’m just in a SS160.
Want an Islander someday for a big/little family
DarrinT
Look at Honey Harbour & Parry Sound . Tons of protected water for small craft. Used to be a canoe tripping guide out of a camp on Beausoleil Island all up and down that coast.
ShoestringMariner
Love G Bay! I’m not experienced enough to know those waters yet. I want to visit Bustard Islands to see the 57 chevy
DarrinT
Decided I'm gonna use this waterproof aluminum deck system and McGuyver it in
cut it up to make struts and reinforce the ribs
ShoestringMariner
Apologies, I wasn’t trying to hijack your thread. I love talking boats and our local waters. PM me if you need a handful of rivets.
decking is an interesting choice. What about using sheet 5052 and rhino lining it?
I’m wondering if there will be torsional stresses on the planks
DarrinT
Sorry it’s the Bourchier islands. Not my pic.
The plan, as it's formulated currently , is to use some of the alu planks as Mcguyvered structure. Under the floor planks I could custom cut and rivet in lateral rib beams that sister for strength and level the floor.
Yah headaches to get them rivetted in right.
DarrinT
Gonna have to either build a shelter or drag her off the trailer using a winch onto some supports - my garage ceiling is a concrete deck - very low ceiling no way she's going in on the trailer.
Moserkr
Chief Officer + Starmada Splash Of The Year 2021
My boat looked like that a few times this winter but she was stripped bare. One more storm coming this weekend and that should be it here. Hopefully your spring comes soon too!
Watermann
The major leaks are probably due to the rotten transom the IO transom assembly needs to have a solid transom or it will leak and sink your boat.
Plywood if sealed and the boat taken care of properly will last many decades and most likely a lifetime. Anything left for the elements to ravage will be ruined, nothing can withstand the elements and time, not even concrete or steel let alone a boat.
DarrinT
DarrinT
The transom is 99% good and solid - only one small section is rotten - one inch high and six inches long where the aluminum bracket holds it up.
When I was going to inspect her when in water I saw a major trickle coming in port side where the transom meets the side of the hull in the 90 degree join and threw up my hands cause if its that bad there then it leaks everywhere.
I beat the hell out of her - I've had nothing but air under her many times in nasty sea states!
ShoestringMariner
She’ll be a wave fighting machine again!!
I saw one just like yours the other day...looking like she wanted to be hooked up and follow me home...no for sale sign on her. Watching your thread with much interest
Watermann
I can only give advice based on my experience my IO Starcraft. Although I can say that older models prior to late 70's have no spray rail chine or rib end braces, IOs 18' and over are very susceptible to cracking in those areas due to the weight of cast iron. In other words check those areas closely for cracks since it leaks like a sieve after being "beat to hell". Loose rivets in the rot compromised decking and side panels on boats without the braces causes these types of hull cracking when used in that condition.
I know it seems like a huge PITA to pull a motor and replace transoms in an IO, been there. Seeing the pic above how the boat is and most likely has been stored for years leads to me to believe transom rot is going to be more pervasive than 1%. Softening of the wood and delamination is another issue plywood faces when not covered from the elements.
Status
