1973 Evinrude Sportser 25hp telltale problem?
minniemousey1
Hi there, just purchased the above outboard motor. Starts ok, runs fine in bucket but no water comes out anywhere. Can anyone help please?
F_R
Honorary Supreme Mariner
Re: 1973 Evinrude Sportser 25hp telltale problem?
First thing is to get it into the water deep enough. It was made to run on a boat, not a bucket. The water pump is in the bulge several inches above the anti-cavitation plate. That has to be submerged before starting the motor.
Water should blow out the hole in the back of the midsection as a generous spray, not solid stream.
minniemousey1
Thanks. Had to try it in a big bucket first because just bought it second hand and wasn't sure if it ran. Didn't have enough water in it - water level was about an inch too low. Spurts water now - thanks again. Out on the water tomorrow!:D
