Little Richard
Thread starter- Joined
- Jun 9, 2017
- 78
Marked firing sequence on top of fly wheel. When putting timing light on plug wires 1,2,and 4 it's good. When on number 3. It shows to be firing on 1 and 3. When warm compression test 120 on all. Strong consistent spark after changing power pack and couple coils. Jumps 1/2 inch gap. Replaced a bad rectifier. Put IR temp gun on exuahst cover behind #1 cylinder and noticed it was running 20 degree hotter than rest and often seems to be running leaner looking at plugs. ( more dry and more white). So my question is am I getting double firing on number 1 and why? Could it be timer base? From black/whites to white/blacks I get 1.2 volts on DVA.
