So my motor was running fine until today. I started the motor and went to put it into gear, when I put it in forward or neutral it will only go in reverse. The throttle moves into position but the motor just stays in reverse. After some research it seems as if it may be the shift rod?!?! Any advice on what the problem may be or how to fix it would be great! ANY help is much appreciated, I am supposed to be fishing a tournament on Sunday.
