1973 evinrude 50373r maiden voyage troubles.
chazmonro
Ok, the engine starts and sounds good, but I have a top speed of 5 mph. I imagine it should go a tad bit faster than that. So what should I do here? It's a 1971 glastron v166. 50 hp should hall that boat an I right?
F_R
Honorary Supreme Mariner
That certainly is the first thing to check. More than likely it is running on one. It isn't producing enough power to plane the boat, and if not planing it isn't going anywhere.
Hot Rod Roy
Does the boat have a nameplate that shows the rated engine size? 50 hp on a Glastron 16 sounds too small. It looks like the boat is rated for a 100 hp engine. Here's a link: http://www.classicglastron.com/71gl-v166-156.html
I have a '74 Glastron CV16 (16 ft.), which has a 115hp Evinrude V4. It runs VERY good!
