NotAClue92
Thread starter- Joined
- Jun 2, 2017
- 15
I bought a 16' Jon Boat with a 1973 Evinrude 18hp motor and it will not even try to start even with spraying a little starting fluid into the carb.. I was told its been about 4 years since it was last ran but it ran great before it sat. It just backfires through the exhaust. Ive cleaned the carb, swapped the plug wires(I read that might be the problem on another post I read) tested the compression( it has 115psi at top cylinder and 113 at bottom cylinder), pulled the flywheel and checked the woodruff key, Ive also checked the reed valves (they're also called a stop leaf according to the parts breakdown) and they seem to be okay as far as I can tell. I cannot figure out why it wont start. This is my first outboard 2 stroke Ive worked on and I'm stumped. Any clue what the problem might be?
