This motor runs good when first started then after increasing rpms I watch the voltage increase a couple volts as it should to charge battery. But when I return to idle and the charging voltage drops I get a cough and the engine quickly dies out. I have replaced stator and rectifier and was wondering where to go from here. I am watching this voltage movement on a engine analyzer as the volts drop engine dies. It starts right back up and is ok at idle and when revved up again and then back to idle volts drop she dies. I am skunked! I am thinking powerpack problem, but would like other opinions. Help! thanks
