1973 envinrude
MooseHootie
I have a 1978 85hp envinrude with tilt and trim. can i take the power head of or my 1973 115hp and bolt it on my 1978 outboard ?
rodbolt
Re: 1973 envinrude
hello<br /> check the shift rod linkage. they changed the hook up sometime about 78 or 79. also you will need to inspect the exhaust ports on the power head adaptors
Dhadley
Re: 1973 envinrude
The mounting base bolt pattern is different. There is also a difference in a water passage that will cause a leak when trying to mount an early p/h on a late mid section.<br /><br />Good luck!
