We always spray PB Blaster three times on any screw, bolts or nuts that are seized,let it sit at least over night or longer.
If you don,t have to move the lean rich mixture screw don,t fight it.
I just replied to a guy that broke his screw, and he can't find another carb to replace his carb, If you wreck or strip that screw you have to buy another carb I don't know if taking the whole carb off and soaking the whole thing in cleaning solution would help.
If you must, try the PB Blaster first gently, then soak the whole carb is some kind of cleaning solution, take the carb bowl off so the cleaner can get to the inside of the screw. Please tell us what happened so I can learn something.
't
