1973 85 hp outboard
thmech
I have a 73 85 horse motor with an issue. Took it out yesterday andbit was running great. Started it up to change locations and while idling it shut down and refused to restart. Got it home after a long tow and it started for a bit and then did the same thing. Bought this motor on a boat about a month ago and have had it out a few times. It used to run a little rough, changed the plugs last week, ran like a champ in the morning and now this. Any help would be appreciated. Thanks.
Joe Reeves
Remove spark plugs..... check spark... should jump a 7/16" air gap with a strong blue lightning like flame... a real SNAP!
Compression... what is the compression psi of all the individual cylinders?
Still no spark?...... reamove the black/yellow wire from the ignition switch. If you now have spark, replace the ignition switch.
Inspect closely the stator under the flywheel to see if a sticky looking substance is dripping down on the powerhead area... if so, replace the stator.
thmech
Thanks. Had to head out of town but will check all the above when I get back.
