Look on the side of the motor if it has a black box with wires running to the coil it's a cdi. If the coil wires come directly out from under the flywheel get your checkbook and a manual. Also what color is the stripe the phase maker was generally red and silver or a combination of those 2. CDIs were blue generally. If it's a phasemaker there are things to test before the points. One thing I can tell you is check all the wires carefully because they are known for falling apart.
