Could you please give me the distance from the top of the pinion gear to the top of the shims on the lower unit drive shaft? Book says to use a "special guage" I don't have. Model # is 65373r. Thank you.
Grayman.... If you don't have that special gauge, and you don't want to take it to some reliable OMC shop to have it shimmed, the best thing to do is to use the same size shims that were used originally.
I guess I should elaborate: My wife picked up the boat. I went to put in lower unit oil. Metal filings....... Pulled out the drive shaft and found it was a mass of fused metal. The shims, bearing shaft were toast. I did as you recomended and was bounced around 'til I ended up with the "man" that told me don't call me I'll call you. I got a shaft on my own now I would love a little help. I am probably over my head but been there before. Thank you...
