1973 65hp Evinrude Triumph lower unit removal difficulty
Cofe
Re: 1973 65hp Evinrude Triumph lower unit removal difficulty
Wow sounds like it's stuck bad. (like you needed to hear that)
Here is a link where a guy cut a window in the mid section in order to access the drive shaft. I would only recommend such a radical approach to be done by a competent weldor. http://forums.iboats.com/showthread.php?t=365676
Sorry to hear that your motor is being so "difficult" to say the least.:( Let us know what you decide to do.
bthompson
I did something like that today. Since it was quite different than trying to take it off the "normal" way, I posted a new thread with some pics. All I ended up cutting was a 1.5" slice in the front of the housing to cut the shaft(actually, I also have a 1.5" diameter hole on the side of it because I wasn't exactly sure where the driveshaft was...used for locating the shaft). I didn't realize it was so far to the front of the casing.
I read that whole thread and I am intrigued with the puller idea. If the slide hammer doesn't cut it, I am going to make a puller(similar to a flywheel puller) and weld it to the shaft. I can use a 1/4 in plate steel or larger angle iron and weld some nuts for threads to run onto the crankcase(maybe make a steel plate to press on that lower seal plate so I don't mess up the aluminum). It is nice to have options!
http://forums.iboats.com/showthread.php?t=386146
bthompson
Still working on pulling the shaft out of the crank, but started on the lower unit since I have to replace the driveshaft. I just got the manual, so I have been working on my own "Special" tools. Here is how I pulled the outside prop bearing and housing. I used my rototiller arm and two 5/16" thread stock pieces(cost $3 total). Next item is the deep snap ring pliers. I might have to spring for that. Mine won't make it into the tube.
Right now, the plan for the powerhead is using a "porta-power" and push on the outer spline of the crankshaft(using a sleeve) and against a heavy washer or cylinder that I weld on to the driveshaft piece. The slide hammer is having no effect and I don't want to work it too hard for fear of damaging the crank or bearings.
More pics as I progress.....
bthompson
The shaft is out! We put some heat on the crank end of the spline and it tapped out with the slide hammer. It was a lot less work that I thought it would be. Forgot the camera so I don't have pictures of the shaft. It was rusty, but also had some tarry junk on it that I think kept it on the shaft. The heat that dad put on it with a torch was just enough to release the hold that stuff had on the shaft. It will take some cleaning on the inside of the crank, but finally, assembly may begin.
I also snapped a pic of the snap ring pliers that I got for taking off the rings in the lower unit. It barely did the job, but at least I did it at home instead of driving to the dealership. Plus, I have a heavy duty snap ring pliers out of the deal.
