1973 65hp evinrude running on one and sometimes 2 cylinders
NC Man
Hello,
I recently purchased a 73 65hp to go with my Cobia CC. Its the size it came from factory .
with and I am restoring to as original as possible
Here is my problem. Took it out on lake. Got almost up to plane and has a power loss. Acted like it was running on one or two cylinders.
Loaded it up and came home. Compression test 118 on all 3 cylinders. Spark good and bright blue at 1/2 inch. Plugs firing bright blue. Carbs removed. Clean as new on inside. air passes thru hi, lo and needle seats with no restriction. Fuel pump clean and delivering proper pressures.
Took it back to the lake.(cause we all know they run good on hose) Ran like on a single cylinder then second cylinder would come in for less than a min. then back to one. popping/missfire sound in carbs when changing cylinders or if throttle up not in gear.
all cylinders changing motor sound if wire pulled and replaced.
Back to the house now. top and bottom plug wet looking. center plug dry.
Not a marine mechanic by no means. Any ideas??????
oldboat1
popping through the carbs sounds like it could be a broken reed.
(think I had that cobia, btw -- kind of a snub-nosed cuddy?)
NC Man
Thanks for the input. I am thinking either that or a bad gasket at the exhaust/waterport plates.
I will try to upload a picture of my boat.
boobie
Do a cylinder drop test on it when it's acting up and see what you find.
NC Man
I haven't in the lake but on the muffs every cylinder changes the run if wire removed on high idle or reg idle.
oldboat1
Thanks for the pics. (Yours is much more modern than mine was. I had an odd looking little cuddy cabin.)
Woodonglass
Honorary Supreme Mariner
I had similar issue with my 76' 85 hp Johnson. Took to a Mechanic and he removed the flywheel to get to the magneto contacts. Totally corroded. He cleaned and polished them and she ran like new!!! I'd start there!
