1973 650 Mercury
bunnybuster
I am having an intermittent starting problem on my engine.
Sometimes it just won`t fire...most times it will start and run fine. I cannot fiqure out what is causing this .
Could the nuetral safety switch cause this to happen? Could it be the switch box on the engine?
So strange because it runs great when she decides to fire up.
Frustrated, and no clue what to do next.
GA_Boater
Welcome aboard, BB. Neutral switch will not allow the starter to operate, that's all it does. It could be the switch box.
A question back to you. Is it hard to start when the motor is cold, warm or both?
bunnybuster
The funny thing is...when it won`t fire..it is when it is cold.
When warm..it starts right up every time.
I have checked the connections pretty thourally and dont see a problem.
I am not really sure how the switch box works?
GA_Boater
Are you using the choke and warm-up lever during a cold start.
bunnybuster
Yes,
I use the choke and warm up lever when cold starting.
Sometimes it will fire right up..other times...no spark on the plugs. So strange.
Like I said, it is intermittent and I cannot figure it out...yet.
bunnybuster
Thanks for your reply...
I figured out my ignition problem...and it was in the distributor.
GA_Boater
:thumb: I couldn't find this topic again. Go boating. :D
