1973 65 hp max rpm 4400
Like to fish
Running a 17 pitch prop on a 1974 tri hull. I know these old tri hulls are heavy, but my question is will having 4400 rms at wot hurt this motor? Also if 4400 rpms is max then how can I set and sync the carbs if I need 26-28max timing at 5000 rpms. Should I switch to a 15 pitch and if I do change to a 15 pitch prop do you think that. Would increase or decrease the top end speed. This is my first powered boat.
