1973 65 HP Johnson won't turnover
Poly00
I have a 1973 65 HP Johnson that cranks but I can't get it to run. I got it it to almost crank one day after I ran bad fuel into it. I had a fuel tank that had water in it and added fuel to it and therefore I ran bad gas into the motor . I flushed the carbs and then flushed and dried the fuel tank and added new correct fuel . WhenbI tried to start the engine it back fired and didn' t crank what do I need to do?
boobie
Check the compression first. Then your spark. It should jump a 7/16" air gap on a tester. How did you flush the carbs ??
Poly00
I flushed the carbs by add new gas to the tank and removing the drain plugs on the carbs and squeezed the the primer until no water came out, only fresh gas. I will check the compression on it and see what it read thanks for the advice. On spark I have a good spark on 2 out of 3 coils, cylinder s number 1 and 2 are good but nothing on 3.
emdsapmgr
Unlikely the coil is bad on #3, but you can swap the coils as a test. If it makes no difference, you'll be into testing the 3 major ignition components. Probably in this order, stator, then the timer base. If both those check out, the it's probably the pack. You can find excellent troubleshooting info specific to your engine at: cdielectronics.com. You'll need a special "peak reading" voltmeter. A household meter won't do it.
boobie
You'll have to get spark on # 3 for it to run right. Go to cdielectronics .com for troubleshooting.
Les Robb
Those engines are about bullet proof if good compression, spark, and fuel. They won't run right but my experience is they will run on two cylinders and at idle it can be hard to notice. Was it running before the bad fuel? Tackle spark but then look carefully at carb rebuild, not that hard with all the manuals and video's they have out now.
Poly00
Thank you all for the information I will be sure to check all that you all has passed to me this weekend and hopefully have good news to share thanks again.
Poly00
All I got my motor running, the problem was that the flywheel key was sheared so therefore it caused the flywheel to slip and never on the correct timing. When I removed the but on the flywheel it was not tight at all. I replaced the key after removing the sheared one . I torqued the flywheel to 100 ft # and that is according to my repair manual. Thank you all for your help and if it wasn't for these forums I would've never figured this out.
