shorehugger14
Thread starter- Joined
- Jun 30, 2008
- 29
All,
I have a 73 50hp that is not getting any spark on the top cylinder and will not start....
Here is what I did: It would not accelerate past idle in the water so ran it on muffs three days ago to try and get it up to max rpm which it appeared to do but then died and hasn't started since. Gas and gas path is good. Pulled spark plugs and cranked it over and found no spark to top cylinder and orange spark to bottom. Swapped orange leads on power pack and verified that top coil is good with spark @ plug. Swapped sensor leads coming from stator but spark didn't swap over so I am thinking the power pack is bad. My only concern is whether or not I screwed anyhting up by running the thing to it's possible death on muffs. I have ordered a power pack thanks to several posts and responses from natashasdad (thanks bro...I owe you) but need to know what else to consider. shrimp are starting to run in my neck of the woods and I want some for the 4th of July.
Shorehugger14
Shorehugger14
