1973 50esl73r lower unit hole
zackyholdem
I have A 50esl73r and when I took it out of the water last year I noticed fluid coming out of a small 1/8 inch hole on the lower unit about 2 inches below the upper fill hole To the right. The hole is through the case and into the lower unit interior. it's hard to tell if the hole is threaded or not.
My question is is this hole supposed to be open or closed. I believe it was closed before because I didn't notice any leaks. I have a 50esl74r as well and the hole is filled halfway down with metal. The manual doesn't reference any hole or screw/plug for a hole. When I filled the lower unit last night no fluid leaked out. I'm thinking the hole should be closed but I have no clue how it got open. The motor was new to me last year
I attached a photo for reference of what hole I'm talking about.
Any help would be greatly appreciated.
Honorary Supreme Mariner
?????----You are not the first new owner to be mesmerized by these drain holes.------The factory folks put them in there to prevent the casting from cracking in cold climates.---Do not plug it and make sure it is not plugged by debris !!!
zackyholdem
Thank you for the info, it was definitely confusing since I have a 74 and that hole is plugged and it looks factory. I was worried about leaving it open as I didn't want water to get in any place that it wasn't supposed to be in.
On more than one occasion have I seen these holes plugged.----Some folks do not know what purpose they serve.
