Got the motor one day, took it out boat worked great accept it would stall a few times after being put in neutral, had to rev it up to get it to not stall going into gear. Seemed to idle rough so i looked up how to adjust the air/fuel mix, ended up flooding it bad. It will start right up with the throttle pushed down on the motor, but stalls out (almost stays running) if the let the throttle go...i tried adjusting the two screws for the air/fuel mix on the carbs as suggested but but won't start without the throttle pushed down....I know just enough about them to be dangerous I guess....Any help appreciated
