1973 50 hp johnson 2 stroke
Don skinner
Hi there my 1973 leaks fuel through the crankcase breather also has begun to run erratically ie revs going up and down.
Any ideas please
Honorary Supreme Mariner
I am not sure about a ---" crankcase breather " ---On that motor ?---Describe what it looks like and where it is on the motor.---Any pictures ?----What other trouble shooting has been done ?
Don skinner
I'll take some photos but it's a rubber hose that comes from the main body of the engine and is vented into the bottom right hand corner of the airnox
F_R
I believe that is a drain hose for the airbox.
Don skinner
just an update i case it helps somebody else i found my fuel problem the idle jets were adjusted to far out reset them to 11/2 turn each and runs sweet with no excess fuel from the breather.
