Finally got the go ahead to buy a boat. It's just a little 16' angler fiberglass boat with a 1973 evinrude 50 on it. Only 1500 bucks so I thought it was worth it. Started right up. Idles fine. Goes into fwd and reverse. No problems right? Well I get it out to launch and can't start it. Back home I go. Jump the starter solenoid and all is well. Just need a new ignition. So I take my little jumper wire and try again since I want to see this thing move.(I can get a new ignition anytime) I get it started and head out. All is well till I get into the gas. Then at about half throttle it bogs down like crazy, like I'm running through mud. And before you ask I was plenty deep. I try a while easing into the throttle never got it up to speed. I give up and go back home. I pull the cover off the motor after flushing the motor since I am in Florida running in brachish water and I notice an oil leak under the flywheel. So I figure it's the upper crank seal leaking air and starving me for gas. Hopefully no need to replace bearing. While waiting to order new seal I look over boat some more. Slight kink in fuel line next to 6 gal portable vented tank. I figure thats not helping either. The line is 4 yr old b1 line. I cut a few inches off to get where the line is nice and round. I see inside the line that the plastic liner is separating and has a yellowish crust between it and outer line. I cut back more and it looks better. I push barbed fitting in and remove to inspect only to find that the plastic line has just crumpled up and pushed back. No good. So I guess I need new fuel line too. I bought an adjustable spark tester as well as compression tester but rain is preventing me from working on it at the moment. Am I looking for 1/4" or 7/16 gap? I have read both on here. And no I do not have a manual for it yet. I guess my question is , is it more likely that a broken down fuel line is causing my problems or crank seal? Can I replace fuel line first and then test on water or do I need to get upper crank seal replaced first? I have read that a special tool is required to pull seal and have also read that a couple screws around the side will pull it out. If I need the tool where can I get it? Since my problem only shows up under load Will getting a drum of water be sufficient ? I am just learning about 2 strokes so forgive me if a little ignorant. I have been searching these forums like crazy though. Any help would or advice would be much appreciated. The wife is not happy I bought a boat that I can't take the family out on yet. I will post compression numbers soon and will check spark as soon as I can verify the distance I should be checking for, I just don't want to stretch it too far and risk shorting a coil.
