1973 4hp Johnson 4R73C will not start
QuackerWhacker
Hello everybody Mark from Canada here.
Let me start off by saying thank you for all the information I have been able to soak up so far. I am extremely new to the world of boats and outboard motors but in anticipation of next years duck hunting season I decided to put together a little rig to help me access some lesser populated hunting spots.
I purchased my first outboard used off the local classified website. A 1973 4hp Johnson model number 4R73C. It seemed to be in great condition and the fellow I bought it from seemed to know his way around it quite well. He did not have a fuel tank or hose so I was not able to see it running (should have walked away I know) but I decided to take a chance and buy the motor anyway.
I stopped on the way home and purchased a fuel tank, fitting and hose. I was sure to get the OMC fitting and hose.
I was going to premix 50:1 a quick search of the forum here led me to a couple threads suggesting 32:1 is a better mix for this motor. I went a head and mixed a tank of that.
I went through the starting procedure and first pull away she went. Sounded great for about 10 seconds but then the bucket of water I had it in fell over so I stopped the motor. Refilled the bucket and now I can not for the life of me get it started. I try every possible combination of throttle and choke but it just will not go. The two carb adjustment knobs are both right in the middle between rich and lean.
I just don't know where to start. I think I can get this running on my own, I really want to anyways. It would be a pretty big accomplishment to be able to say I got it running on my own.
Thanks for reading, and thank you in advance to anyone who might be able to assist me in getting this going.
I'll take some pictures and maybe a video of me trying to start it later today if that would be of any help.
Xcusme
Welcome to iboats QuackerWhacker !!
OK, First things first....Get your motor submerged ENOUGH ...by that , I mean deep enough in water. By the sounds of it , the water bucket it too small (short). The water pump must be deep enough to pump water up to the motor. Try again...with the carb set as follows. Top and Bottom needle valves set to 1 turn out from GENTLY seated. When she runs , you will feel water spraying from the 3 or 4 small holes just below to power head. Let us know what it does.
QuackerWhacker
Thanks for the reply!
I took some photos to show the motor and the bucket of water I have it in. Really sorry they are sideways I am unsure of how to correct that.
I gently seated both needle valves then backed out 1 turn. Still no luck.
There is blue spark from both plugs. I also took the carb off and removed the bowl. The gasket is in great condition and the bowl is spotless. I didn't take the carb apart any further but from what I can see everything is extremely clean.
I guess my next question is should I get bigger container for water? At the risk of about $12 would new spark plugs help? Current plugs seem fine but maybe its worth a try?
I used 87 octane fresh from the pump yesterday and mixed with quaker state 2 cycle motor oil. The bottle said for pre-mix or injection engines.
hidef
You need to use a garbage can you want to make sure you have plenty of water.
The engine ran for ten seconds and then died. Did you pump the primer bulb back up so that it was hard again? Sounds like you aren't getting fuel to the engine.
A major issue with these engines is the original fuel pump and fuel lines do not like ethanol. Ethanol will cause them to break down over time. Judging by the photo of the fuel pump you will need to replace the pump the line from the fitting to the fuel pump and the line from the pump to the carb. The dealer will have the correct diameter hoses in stock and most likely the fuel pump to. I would also install a new water pump.
Ok, you have spark on the plugs.----But do you have good spark that will jump a gap of 1/4" or more.----Do that test first.----The recoil starter is not robust on these motors.----Get the motor in proper tune before you damage the starter !
QuackerWhacker
Ok so I got a bigger source of water.
Put in new fuel lines.
Put in new spark plugs.
Still won't start but sounds more like it wants too now.
The spark is good and blue and can jump a 1/4" gap.
I removed the fuel line to the carb and pulled the starter slowly. Fuel shoots out when I do this.
I am stumped! Might end up taking it to a small engine mechanic this week but thank you very much for the help I received.
AlTn
if this differs from your starting procedure, try this one....advance the throttle as far as it will go while the motor is in neutral...full choke....you should get at least a grunt within 4 pulls...push the choke in to a 1/2 choke position...the motor should start...once it starts you'll need to cut the throttle down...depending on that particular engine you can probably kick the choke off as well...let it warm up some before trying to go to low idle...do not shift into fwd or reverse until it can run at low rpms
QuackerWhacker
I will try this now however this motor does not have neutral or reverse. When she's on she's on.
AlTn
oooops...well just be quick on the throttle if it does start
QuackerWhacker
Still wouldn't go. It sounded like the motor sneezed a few times when I was trying.
I just bought a compression tester and will get that done tonight. Should I maybe make a quick video of me trying to start it? Don't know if that would help someone point me in the right direction or not.
I haven't been able to find what is a normal compression reading for this motor does anybody happen to know?
AlTn
75 lbs. and greater and you should have an engine you can work with..both cylinders within 10% of the highest reading
AlTn
any chance you've switched the plug wires?...normally the upper wire will have a small metal band pinched on it
QuackerWhacker
Ok so I did the compression test. I also found the service manual and have been reading as much as I can to learn how this thing works. It's really interesting.
Anyways the top cylinder reads 60 PSI. It builds compression over 5 pulls.
Bottom cylinder reads 0 PSI.
Ok so I now know why my motor won't go.
Will update in the morning. Thanks for everything so far!
QuackerWhacker
Ok so after staying up until 4 am attempting to educate myself on the subject I felt comfortable enough today to begin a bit of surgery on the motor.
I removed the cylinder head and the gasket was in horrific shape. Completely blown apart on the bottom.
Now I am about to order the gasket and what I am wondering is if I should do rings as well? From what I have read so far, when my top cylinder builds its compression over 5 pulls that is an indication of worn rings. But with the head gasket in such poor shape I wonder if this might be the only issue?
AlTn
cylinder walls scored?...pistons ok? < nothing more than carbon evident >....read up on surfacing a head using sand paper and a flat surface
Crosbyman
great little engines... dont jump around to much
1- get that head gasket replaced and confirm compression numbers back to us
2- You have sparks now you need fuel in the pistons. make sure the carb is serviced properly see link . the 3hp and 4hp carb are very similar design and procedure wise .
all carb passages must be cleaned and air flushed.
http://www.maxrules.com/fixtuneitup.html
QuackerWhacker
Hello! Sorry for the absence the outboard took a back seat while I waited on the new head gasket to arrive.
So now that I have the gasket and am all excited to try it out I can't find the torque value for the cylinder head. Would anybody happen to know this?
I have my wife printing the service manual for me today as it is too difficult to read on the computer but just thought somebody may know and I could get at it this afternoon.
Also should I use a gasket sealer of sorts?
QuackerWhacker
It is ALIVE!!!
Thank you very much for all the help. The problem all along was a damaged head gasket. The engine fires up right away and purrs quieter than my house cat.
Now to wait for October to put a beating on some mallards.
