1973 40hp Johnson Shift lever connector for lower unit disconnect...
kmercury
Hello,
I am attempting to replace the impeller on a 1973 Johnson 40hp. I need to disconnect the shift lever but from what I can tell, the coupler is inside the exhaust housing and not on the front of the motor like other Johnsons.... Can anyone help with this? Do I need to lift the powerhed off to get to the coupler?
Thanks
boobie
Re: 1973 40hp Johnson Shift lever connector for lower unti disconnect...
Look on the side of the exhaust hsg and you'll see a little cover held in by 2 screws. Remove that and you'll see the shift link coupler. Remove the bottom screw and the linkage should disconnect. Go to shop.evinrude.com , look up your mtr in the parts diagrams and you'll get a better idea.
kmercury
Excellent.... thats it.... I was looking at the parts diagram on Marine Engine and it looked was not that clear.
Thanks.... I will be fishing yet this weekend!!!!!!
boobie
When you put the g/c back up and attach the shift rod to the connector make sure you align the bolt hole in the connector with the indent in the shift rod.
kmercury
Will do.... thanks
