1973 40HP Johnson remote looking for tiller options.
budsbud662
model 40EL 73D
I was able to get this 40hp motor for a great deal. Its a pull start.
I currently have a 1973 25hp tiller. And its on its last legs.
Id perfer getting a tiller kit for the 40hp and having two operational motors, however
Would i be able to use the 25hp tiller as a parts doner to make my 40hp a tiller? Do they evan MAKE a tiller kit compatible?
This does NOT need to be a perfect swap no matter what route i go.
Can i purchase a tiller handle off ebay that would bolt up, and at least have the throttle on the tiller handle? I can get by rigging the shifting up if i have to. Just looking for a rock solid way of rigging this motor. It's for duck hunting and needs no visual appeal.
Does anyone have any experience. The only thing i really dont wanna do is a big brass pipe with remote controls on the other side of the seat. Now that would be RIGGN!
THanks Justin!
ditchen
Re: 1973 40HP Johnson remote looking for tiller options.
been there done that. Motors are totally different.
I started out with a 72 25hp tiller and moved to a 76 40hp (remote control). The motor style has been
I obtained the 40hp tiller handle from ebay and made my own wire harness to a start and stop switch I had mounted on plate on the front of the motor.
budsbud662
so, what year tiller handle's will work?
and they should bolt up fine and have throttle operational once i connect the linkage?
The electrical doesnt bother me.. that stuff is easy..
Also how did u go about install the manuel shifter?
F_R
The tiller for your motor was made from about 1955 up into the 1970's. Used on 30,35,40,50,60,75hp motors and more. Look for the one with a single bolt holding it on. You will also need the shaft & gear that goes through the steering bracket to replace the emergency throttle lever presently on the motor.
budsbud662
Are the lower horse power motors the same style, with a shorter length?
they look very simliar. lots of handles up to 25hp for sale, very few over 25hp
thanks, Justin
budsbud662
The urgency for the tiller handle just went up a notch. I ruined something on my 25HP this AM.
So im looking all over the place for the tiller handle that fits the 40hp above.
Does anyone know of a spot that might have such a thing.
It is the same model as above.
budsbud66@live.com thanks.
