1973 25hp evinrude gearcase wont go into forward gear
zommer
Hello everyone.I put new seals in the gearcase and now the engine will not shift into foward gear. It will shift into reverse and netural.
When I was reinstalling the clutchdog was I suppose to position it into forward gear before I reassembled it ?
Thanks for any help
Honorary Supreme Mariner
I usually put the clutch dog into the forward gear.-------That just makes it easier to put the pivot pin in correctly.
kbait
Check shift shaft coupler and make sure both bolts fit to their respective shaft detents..
