1973 25hp evinrude gearcase seals and impeller
zommer
Im putting new seals in the gearcase of the engine. I have scotch-weld 847 to seal the gearcase halves.
Can I use the 847 to put on the driveshaft seal and the gearcase head assembly seal or should I use a different adhesive .
Also the impeller housing plate does not have a gasket above or below it.
Should I put gasket sealant under the plate and on top of the plate to seal to the impeller housing.
And if so whats the name of the sealant ?
Thanks, Ed
Chrisravosa36
Is it the 2 piece gearcase? if so there is a spaghetti seal you use for it. If not, the usual ring seals are required. . As for the gasket, look on the diagram, they should be one.
F_R
Honorary Supreme Mariner
Thanks, Ed
Your 847 is the proper sealant for the gearcase halves. While not the "correct" sealant for the OD of the seals, it will be fine anyway. Yes you should use it between the pump plate and gearcase, but nothing is necessary between plate and pump housing. NO gasket is used.
"Correct" sealant for seals OD is OMC/BRP Gasket Sealant. Liquid Permatex in the can is an acceptable substitute. Not real critical, other gaskets sealants will be ok also.
zommer
Chris,
Thanks for ur reply and help.
zommer
Thanks for the help J_R .
So u are saying I can pickup a small tube of permatex , say like u would use on a waterpump on a car and that will be fine to coat the outside of the seals ?
F_R
The liquid stuff that comes in a can with a brush under the lid. I forget the number, just look for the can.
zommer
There is one other question I forgot to ask.
In my old repair manual it says to pack the inside of the seals with omc triple-guard grease.is that the name of the grease ?could I use a hi-temperture axle grease instead.
zommer
Sorry bout the question about the omc triple-guard grease.
I just goggled it after I asked the question and found it.
This is my first time resealing a gearcase and waterpump.
Grease is used between 2 seals on newer motors.--I do not believe this applies to a 73 model 25 hp.
zommer
I found the can of permatex J_R was talking about I think.
Would it be Permatex High Tack gasket sealant #80062 ?
zommer
Can any one tell me if permatex high tack gasket sealant #80062 will replace omc/brp gasket sealant to use inside the gearcase of my 1973 evinrude engine
